706 Power outage
bryan
02-05-2002 19:06:10
I was operating my tractor tonight and it just died. I have a new battery, have power to starter, and to voltage regulator but, no power what so ever. No lights, no dash displays, and fuse is good. Could it be posible that the regulator is going bad?
Matthew
02-06-2002 16:41:21
 Re: 706 Power outage in reply to bryan, 02-05-2002 19:06:10
If you have a 706 gas, then your problem is a bad condensor. You say it has power until you let off the starter button, then you have a bad condensor.
Boss
02-05-2002 20:19:31
Sounds like a problem in the wire harness,and you lost power to the ignition switch. Check all plug in connectors some might be corroded, or a wire may have come unplugged.
bryan
02-05-2002 20:23:48
 Re: Re: 706 Power outage in reply to Boss, 02-05-2002 20:19:31
The power came back but when I push the starter button I lose power again until I let off the starter button. I did find some loose connection in the harness also, but i still think it is in the switch somewhere.
vern
02-05-2002 22:59:28
 Re: Re: Re: 706 Power outage in reply to bryan, 02-05-2002 20:23:48
have had the same problem with my 504 in the past----tore apart and re-plugged every wire in the harness---turned out it was a dirty connection to the battery on the positive cable--not the connection to the post but where the cable clamps to the connector.
