Will a IHC 31 mower work on a F12?
Bob
02-07-2002 11:37:04
I am thinking about buying a IHC model 31 sycle bar mower for my 1935 F-12. What kind of lift mechanism do those mowers use? And are there any other problems I might run into? My F-12 has the old style fixed draw bar that doesn't have the quick change type hitch like on later 36 and up F-12 and F14s, H and Ms so it would have to connect to the draw bar I suppose. Any help would be great.Thanks
Charlie
02-07-2002 13:56:02
 Re: will a IHC 31 mower work on a F12? in reply to Bob , 02-07-2002 11:37:04
I think that model mower would bolt to the drawbar but I'm not positive. You would need a version with a manual lift and you would need a pto adapter to connect the larger mower pto to the undersized pto on the F12.
Bob
02-08-2002 12:18:45
 Re: Re: will a IHC 31 mower work on a F12? in reply to Charlie, 02-07-2002 13:56:02
Thanks Charlie, I have the PTO adapter already, but I am not sure if this type mower came with hydraulic lift or a mechanical lift run off the PTO. The pic I saw of it doesn't look like there is a cylinder on it, but the pic is lousy. The mower was used on a Farmall A if that helps.
