Literally ran over Farmall A
Bad luck Brad
02-15-2002 16:17:26
The hydraulic pump on my 1976 White 2-102 went out at a very bad place . Going down the lane to the shop . Could not stop , or turn , crashed into the shop and ran over the rear end of my Farmall A ! Finding some parts cheap , having local weld shop make others up . Can anyone tell me what the total (end to end) length of the left side differential shaft is ?
Hendrik
02-16-2002 10:23:34
 Re: Literally ran over Farmall A in reply to Bad luck Brad, 02-15-2002 16:17:26
The left diff. shaft of my '48 Super A is 9 1/16 inches long. (Maybe 9 3/32 because I only have a measuring tape available now.) My tractor is almost totally disassembled, so if you need more dimensions, post a reply to my reply and I'm more than willing to help you. Sad story though.
Brad
02-16-2002 11:19:55
 Re: Re: Literally ran over Farmall A in reply to Hendrik, 02-16-2002 10:23:34
Thank you for the help , Hendrik ! The weld shop bent the diff. shaft back and it streched out to 9 1/4" ! He will need to make me one up then . Thanks again , Brad
Hendrik
02-18-2002 09:35:40
 Re: Re: Re: Literally ran over Farmall A in reply to Brad, 02-16-2002 11:19:55
The extra length is no problem I think, if you grind the exess off of the inside end. Getting it purely straight is another matter, because on such a short axle the slightest bend will ruin the outside ball bearing and the bearing(s) in the differential as well; and it will wreck the oil seal. Good luck, Hendrik
Glenn(WV): OUCH!
02-15-2002 19:25:26
My condolences for your A! Glad you weren't hurt, too!
Bob Kerr
02-15-2002 19:18:21
oh my! I hope you can get it and the shed back together ok. I know this is a day late kind of info, but I have a friend who designed an auxilliary back up system for Hydraulic systems on the large Catapillar Mining trucks so they wouldn't drop off the edge of those huge copper pits, that could have saved you a bunch of work. The second pressure fails, the back up system goes on. If you want email me and I can put you in touch with him if you want to try to put something like that on that White.
RayP(MI)
02-15-2002 18:06:41
And I thought I had a bad day! Sympathies...
