Farmall A plows?
Bandit
02-17-2002 18:41:52
How big of a drag plow would be recomended for use w/ an a Farmall A? Number of bottoms etc...
Carl
02-18-2002 09:04:58
 Re: Farmall A plows? in reply to Bandit, 02-17-2002 18:41:52
I have a "39" "A". I just plowed 9 acres last fall. I plow a 1 acre patch and a 8 acre patch. the 8 acres took me 23 hours. I used a 1 bottom 12" mounted plow. I have black jack soil and my outfit had trouble in some places. The manual lift on the mounted plow will really beef up your arm!!
Haas
02-18-2002 06:44:34
The most usual plow for the A is the single bottom 14 or 16 inch mounted plow made for it. It will pull that in 2nd gear in most soils. These plows are around at salvage dealers, and you should be able to pick one up for about $100.
gene b
02-18-2002 05:21:02
you will need plenty of rear wheel weights to pull the 2-12 make sure the hitch on the plow is set correct also you wont want to tackle any large fields unless the pay is good the A is better with the one bottom mounted plow made for it
Robert in Md.
02-17-2002 19:34:20
An IH A will pull a 2 bottom l2 inch plow fine.
