Adding 560 hydraulic fluid
Bob
02-18-2002 19:32:50
I have a 560 diesel which needs hydraulic fluid, but I'm not sure where I add it and what type of fluid I should use. This was my father-in-laws tractor and he has passed away, so I really don't have much to go on. Any help would be much appreciated.
Thanks!
Keith B
02-18-2002 20:12:25
 Re: Adding 560 hydraulic fluid in reply to Bob, 02-18-2002 19:32:50
There is a triangle shape cap(plate) on the top of the deck with three bolts in it. (Similar to what the gear shift goes in, and to the right of it) That is where the hydraulic/transmission fluid is added. First remove the plug on the left side of the transmission case. This is the full/level plug. Add fluid until you see it coming out the full/level plug. Use Hy-Tran fluid by Case-IH or something comparable from TSC.
