2 PT hitch has shrunk
300 Randy
02-19-2002 05:34:47
The Two point hitch on my 300 utility is about 4 inchs narrower then it should be. Every time I go to hook something up I have to use an old car jack to open it up to 28-29 inchs. When its relaxed its at about 24". I have jacked it open to 32" but it always comes back. Will I have to take it all apart and have that big U shaped bar pulled out until it stays where its suppose too? It would be nice to get rid of the car jack that I carry behind the seat.
DALE KITE
02-19-2002 16:35:57
 Re: 2 PT hitch has shrunk in reply to 300 Randy, 02-19-2002 05:34:47
HAD THE SAME PROBLEM WITH 300U I BOUGHT AT AN AUCTION THE PART THE SOCKETS ARE CONNECTED TO WERE BENT THE DRAWBAR WOULD NOT FIT, TOOK IT TO THE LOCAL VO AG SCHOOL AND HAD IT STRAIGHTEND.
big fred
02-19-2002 07:59:40
Randy, I think 24 inches is the right number. I know it is about 2 inches too narrow for a Cat I 3 pt hitch, which is why the correct 3 pt adapters have a jog in them.
big fred
02-19-2002 11:42:21
 Re: Re: 2 PT hitch has shrunk in reply to big fred, 02-19-2002 07:59:40
Oops, upon looking thru the archives I see 28 inches is the right number. I'd put a spreader bar in there to keep the sockets properly spaced. I must have the same problem as you with my 300U, except that I only use 3 pt equipment, so being 2 inches narrower than Cat I can be fixed the same was as 2 inches wider, just switch the 3 pt adapter tongs side to side.
Hugh MacKay
02-19-2002 15:19:10
 Re: Re: Re: 2 PT hitch has shrunk in reply to big fred, 02-19-2002 11:42:21
Fred: It sounds to me as though he is using this tractor on 2 point equipment.
