How can I tell????????????
Andy Van G.
02-20-2002 14:08:14
is there a way on the serial plate to tell if its a super a model or just a plain a? if not, how else could you tell, hydralics could of been taken off, etc... just how do you tell before you determine the year of it, you need to know wether its an "a" or a "super a".
Hugh MacKay
02-20-2002 16:44:45
 Re: How can I tell???????????? in reply to Andy Van G., 02-20-2002 14:08:14
I guess you have the serial no. item covered. If you do not have a serial no. The top of casting where hydraulic goes is flat to acomadate the hydraulic on Super A. The same casting on a is not flat, but rounded.
SAm in NS
02-21-2002 11:46:10
 Re: Re: How can I tell???????????? in reply to Hugh MacKay, 02-20-2002 16:44:45
About casting differences. I think it was only the Super A's that had the place on the block to mount a hydraulic pump. SAm in NS
Hugh MacKay
02-21-2002 13:03:45
 Re: Re: Re: How can I tell???????????? in reply to SAm in NS, 02-21-2002 11:46:10
Right on Sam
SAm in NS
02-21-2002 11:46:02
Dave_Id
02-20-2002 15:01:58
Other than the hydraulics, or lack of, the Super A ser.# started with 250.001. Also casting dates can also give you a clue. 1947 was the stop year for the A, and start year for the Super A
Andy Van G
02-20-2002 15:21:23
 Re: Re: How can I tell???????????? in reply to Dave_Id, 02-20-2002 15:01:58
So the serial number began at 250 001 and up. And the a's were under that number. Thanks a lot Dave!
