Farmall H. Cracked head or not?
atw
03-05-2002 09:32:43
I'm wondering if my 1947 H might have a cracked head. When I start the engine after its sat for a while (could be just overnight)a noticable amount of moisture comes out of the exhaust. It happens either with, or without the muffler on. Is this just condensation forming from the hot exhaust running through the cold manifold, or is it a sign of bigger problems. The engine was rebuilt about 12 years ago, and runs awesome, and the antifreeze level does'nt seem to going down at all. This is my first tractor so I dont have any experience to look back on.
sod
03-05-2002 12:30:00
 Re: Farmall H. Cracked head or not? in reply to atw, 03-05-2002 09:32:43
or frost this thime of year . I'll bet it ain't cracked.
good luck sod
Steven@nd
03-05-2002 10:34:57
Funny thing you bring that up. If you were to talk to my local machine shops (3 of them) they all say the same thing: heads on H's and M's are always cracked! Yeah, they probably are, but does it cause any problems? I doubt it. Our M was running for several years just fine until a valve burned off and we took the head of to get that fixed and a new seat put in and OH NO! The head was cracked! And it had probably run that way for 20 years! Guess what else? My H head is cracked too! And I'm going to put it together that way and it will probably run another 50 years with it cracked. Sorry to rant, just disappointed in the local shops right now.
Anyways, as long as you aren't getting white smoke I wouldn't worry.
Steven
C Kulig
03-05-2002 20:11:43
 Re: Re: Farmall H. Cracked head or not? in reply to Steven@nd, 03-05-2002 10:34:57
HMMM, burnt valve,cracked head,deja vue!
Think I got ----ed ?
jal-SD
03-05-2002 09:53:34
Does it miss when you start it? Does it smoke when it idles for a while & is the smoke white? I'd guess that its probably condensation, if the answers to the above questions are no, as the heads on H's are pretty tough, unless its been improperly torqued or someone got it way too hot or allowed to get way too cold w/o antifreeze. (My $0.02 worth. jal-SD)
LazyHorse
03-05-2002 09:48:39
If you're coolant level isn't going down, and you're not seeing noticeable amounts of cooant in the oil, chances are it's just condensation. If you don't work the tractor hard enough to get it to operating temperature condensation will form very easily.
