450 d ...no ta
big mike
03-08-2002 16:42:59
im wondering what work is involved in correcting a ta problem.some years ago my father had this tractors clutch replaced,and when it was done,the 450 didnt have any low in the ta,when it worked properly before.i was told that the ta has a one way roller in it and can be installed backward,is this true?also what is this tractor worth,it has good sheet metal quick hitch,p.s., and is complete and runs strong.....thanks,,mike
RPM
03-09-2002 09:08:21
 Re: 450 d ...no ta in reply to big mike, 03-08-2002 16:42:59
I would say that external linkage on clutch & ta is misadjusted, the clutch job should not have anything to do with the ta internally. Its in the same housing but separate compartments.
the tractor vet
03-08-2002 17:23:54
Have you ever tryed to adjust the linkage it may be that simpal or ya might just have to tare into it and fix it as far as price i won't even try to tell ya since i can't look it over and check it out .
