BOB MELVILLE where are you when I need you.
Big John
03-11-2002 21:41:57
Bob I am in need of your help. My new M came to me with a 12-volt conversion that had been done with a one (1) wire Alternator. While the Alternator was installed well, the wireing is a wreck. They tried to use most of the old 6-volt wireing and it is a mess. I want to start from scratch and build a new system. Could you post information similar to your article using the Delco 10SI, (WHICH WAS OUTSTANDING) only with the information for a one (1) wire alternator? I want to thank you in advance
M man
03-12-2002 04:58:38
 Re: BOB MELVILLE where are you when I need you. in reply to Big John, 03-11-2002 21:41:57
Look to left side of your screen click on articles,go down list to 12v conversion, you are home free
Bob M (w/link)
03-12-2002 04:54:39
Big John - Been laying low the last couple of weeks on account of activity at work. Anyway punch below for the wiring diagram you're looking for. Hope this helps! ...Bob M
Bob M (w/link)
03-12-2002 04:55:22
Bill Newton
01-01-2003 12:54:39
 Re: Re: BOB MELVILLE where are you when I need you. in reply to Bob M (w/link), 03-12-2002 04:55:22
Did a 12 volt conversion to a 1952 Super W6. I followed the wiring diagram for a super M. I used the warning light that is suppoed to go out when the tractor is running. Everything works great except the light doesn't go out, it gets brighter. What's wrong?
Bill
Larry W.
03-12-2002 05:58:08
Bob, I did this to my M a few months back, and everything works fine, except, if I leave the bqattery hooked up, it seems to drain it over a week or so. It hasn't went dead yet, because I have learned to unhook the battery when I shut the tractor down. did I do something wrong? By the diagram, I have everything the same way. Thanks for all the electrical help.
Bob M
03-12-2002 08:43:15
 Re: Re: Re: BOB MELVILLE where are you when I need you. in reply to Larry W., 03-12-2002 05:58:08
Larry - That's a roblem often encountered with "single wire" alternators. Some versions have a regulator that draws significant current even when shut down - enough to drain the battery after a few days of being idle. That's why I'm not a big fan of single wire units. Pulling the ground cable off the battery after shutting down for the day is probably your cheapest workaround.
Note however the problem could also be a bad diode as Lou suggests...
LOU
03-12-2002 07:22:43
Larry, your alt may have a bad diode plate in it. My "H" uses a one wire, new battery, starts great even after a couple weeks inactivity.
LOU
03-12-2002 13:39:11
 Re: Re: Re: Re: BOB MELVILLE where are you when I need you. in reply to LOU, 03-12-2002 07:22:43
Oh,,Larry, also charges up in a couple of mins.
