LEAD ADDITAVE
BOBBY SHAFFER
03-16-2002 01:04:26
THIS FORUM IS THE GREATEST THING ON THE WEB. EVERYONE IS SO HELPFUL. MY QUESTION IS SHOULD I BE USING A LEAD ADDITAVE IN MY S/M FARMALL? THANKS IN ADVANCE..... BOBBY
ben
03-16-2002 19:30:29
 Re: LEAD ADDITAVE in reply to BOBBY SHAFFER, 03-16-2002 01:04:26
that all depends on if you have had the head redone and has hard seats put in,if thats the case you do not need the additive but you will have to turn down the carb most likely cause the alcohol gas will clean it out. if you still have the original engine with no work done on it you might want to use additive to save the valves.
Steven@nd
03-16-2002 06:04:29
Nope, lead substitute is a waste of money - at least that is the general consensus around here.
Steven
Rick
03-16-2002 04:26:07
I posted the same question for my Farmall A sometime ago. All the responses I received were the same- don't have to! Regular gas is OK. Don't know if anything has changed since then though- so far, so good for me.
