856 1st gear doesnt work in all ranges and with T/A back or forward?
A-man
03-25-2002 16:51:39
My neighbor has a 856 with the first gear not working, Is it something major? The owner says it doesnt work in any range or either with T/A foreward or back. What could the problem be? Thank you very much
JD Humm
03-26-2002 02:21:02
 Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to A-man, 03-25-2002 16:51:39
I am afraid you do have a major problem, we had this happen to a 1256 a year after a TA replacement at the dealership. A nut backed off a large shaft, allowed first gear to slide out of alignment, it would not work in any range like you are saying. The large shaft was ruined as was a couple of gears. I did the work myself, that was 25 years ago and don't recall what all was involved but do remember the tractor was split in 3 pieces to fix. Sorry but it sounds like the same deal with your 856, that was a common problem on several 56 series tractors in this area at that time.
A-man
03-26-2002 16:05:45
 Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to JD Humm, 03-26-2002 02:21:02
What is all involed in replacing this part? What parts of the tractor needs to be split?
JD Humm
03-27-2002 02:22:57
 Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to A-man, 03-26-2002 16:05:45
The transmission had to come off the tractor which means a 3 piece split, as for the nut on the shaft it will be obvious once the transmission is removed. I am 99% sure that is going to be the problem, may as well plan on a new shaft and probably a couple of gears, may see more once you get into it. Sorry to bear bad news but have seen this one before.
Les Repair
03-25-2002 17:41:05
If you refer to first gear as number 1 in the speed transmission or the 1-2-3-4 range, more than likely the nut has come off the countershaft in the range transmission. If you were real lucky, it could be a linkage problem.
Keith
03-26-2002 08:36:54
 Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to Les Repair, 03-25-2002 17:41:05
OK Les and JD...you have me worried a bit. I am about to put a TA in a 856 this weekend. Tell me what to look for initially and what I should check before closing it back up to avoid this from happening later to my tractor. Should I just torque the living H out of this nut on the range countershaft or what? BTW the tractor has ALL gears now and I want it to have all when I am done. Myself and another experienced mechanic are doing the job.....we've just never done this particular task before. Thanks in advance.
JD Humm
03-26-2002 15:45:22
 Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to Keith, 03-26-2002 08:36:54
That is precisely the shaft that lost the nut on Dad's 1256. I recall the keeper tab wasn't bent over and I don't think the nut was ever torqued properly to begin with, the tractor most likely didn't have 200 hours on the TA job when this happened. I just torqued the nut to specs and made sure the tab was bent down like it was supposed to be, never had anymore trouble out of it. I had heard of this happening to other tractors though. Maybe locktight as well????? ?
JD Humm
03-26-2002 15:46:44
 Re: Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to JD Humm, 03-26-2002 15:45:22
By the way Kieth, I am the "ugly" guy on the 504 in the photo.
Keith
03-26-2002 20:14:09
 Re: Re: Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to JD Humm, 03-26-2002 15:46:44
Thanks for the advice, JD. I will torque then check and re check the tab to hold that nut in place. As for the photo...you busted me. I said that but....you cannot expect to post your mug on the web and not have anyone bust your chops! You are better looking than me, I was just kidding. I enjoy your pics and advice.
JD Humm
03-27-2002 15:17:03
 Re: Re: Re: Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to Keith, 03-26-2002 20:14:09
Keith I know you were just giving me a hard time, no offense taken, just had to post you back. Check your email, sent you a note and photo of our line up. Good luck with your 856.
A-man
03-25-2002 18:26:28
Is this a big repair job? What is all involved in the repair if it is the nut on the countershaft as you say? Thank you very much Les Repair
John M
03-26-2002 18:25:34
 Re: Re: Re: 856 1st gear doesnt work in all ranges and with T/A back or forward? in reply to A-man, 03-25-2002 18:26:28
The speed trans(where 1st gear problem is) must be dissambled when doing a TA any way. There are plenty of used or new generic parts available, so you are not looking a huge expence. The reason 1st gear isn`t working will be evident opon dissambly.
