Cast Dual Wheels on a 856?
A-man
03-28-2002 23:11:02
Was this a option for the 856? Or is this just a add on? Could you get this from the factory with cast dual rear wheels?
RPM
03-29-2002 06:16:38
 Re: Cast Dual Wheels on a 856? in reply to A-man, 03-28-2002 23:11:02
I dont recall for sure but dont think that cast wheel duals were a option on these tractors, anyway the steel wheel duals listed were for off & on usage, they were cheaper & lighter, cast duals didnt really come until Case-IH on 71 Magnum series. I have been at a dealer since 1960.
JD Humm
03-29-2002 14:55:04
 Re: Re: Cast Dual Wheels on a 856? in reply to RPM, 03-29-2002 06:16:38
I have a question for you, RPM. The unloader valve, part of the hitch lift system on my 504 is plugged and cannot be rebuilt. Repalcement part is no longer available through Case IH. What do I do, take a chance on one from a junk tractor or do you know of an aftermarket outlet for such parts?
RPM
03-30-2002 06:25:51
 Re: Re: Re: Cast Dual Wheels on a 856? in reply to JD Humm, 03-29-2002 14:55:04
I am a little fuzzy on what part you need exactly, If you could furnish part number I have a system I could check out to see if stock was maybe available at a dealer somewhere or else see what it fits besides 504 when you try to find a used one. This doesnt cost anything to do, just takes a little time. If you are looking for part 376766R1 it fits a lot of tractors, 44/74/4210, etc.
JD Humm
03-30-2002 13:10:35
 Re: Re: Re: Re: Cast Dual Wheels on a 856? in reply to RPM, 03-30-2002 06:25:51
RPM I will look up the part number in my parts book this evening and post you either on this forum or Red Power this weekend sometime, thank you very much.
