Magneto
Bruce Banning
03-29-2002 15:51:50
I wonder if I can convert my W6 from a magneto ignition to a distributor system ?? If this is possible , what parts do I need and does anybody have any ? Thanks, BB in Western PA.
Bruce Banning
03-31-2002 15:33:53
 Re: Magneto in reply to Bruce Banning, 03-29-2002 15:51:50
Thanks to all for the responses. I am purchasing 2 distributors tomorrow. This WWW is great !! Take Care BB
Farmall Gray
03-30-2002 18:04:14
You may also need to change the generator. The generator for battery ignition was higher output to keep up with the extra load of the ignition system.
klf
03-30-2002 18:08:07
 Re: Re: Magneto in reply to Farmall Gray, 03-30-2002 18:04:14
I have never heard of that. We I sell generators for Farmalls, there is no option of what type of ignition system they have.
Old Hand
03-30-2002 05:54:46
Bruce almost any distribitor off of 4 cyl. IH tractor from 1940s and 1950s will work. You should be able to find everthing you need from salvage yard for about $125. That is going price in my area. If you want to cut cost you can convert magneto to batter ignition.
klf
03-29-2002 16:51:38
Yes, this is possible. You need to add a coil, dist, and a different kill switch. You will also have to run a hot wire for your coil; which you would run to one side of the switch. The wire that runs from the existing switch to the mag you can use to run from the coil to one side of the new switch. Central Tractor use to have a conversion kit, but you know the rest of that story.
Bruce Banning
03-29-2002 20:09:18
 Re: Re: Magneto in reply to klf, 03-29-2002 16:51:38
Thank you for your reply. Question---What distributor should I use?? re Central Tractor, Our local CT in Butler, PA recently closed. I bought their fork truck. That was the last piece of equipment or goods left in the place. It was a sad day to have to drive away from a place that was once a source of neat stuff but now is only an empty building.
