Order Farmall Cub Parts Online
Will Cub crank fit into a super A ????
Brian
03-31-2002 09:30:37
Would like to confirm if the crank from the cub is the same as the cranks used in the A.
Thanks.
Big John
03-31-2002 12:59:07
 Re: Will Cub crank fit into a super A ???? in reply to Brian, 03-31-2002 09:30:37
Brian, they are two totally different engines and nothing from one will enterchange with the other engine. The engine in a Super "A" is a model C113 and the engine in a Cub is a model C60. The crankshaft journal diameter for a SA is 2.1245 and for a Cub is 1.6235, just for starters
SAm in NS
03-31-2002 11:12:00
Which crank are you refering to? The crankshaft in the engine or the hand crank for starting? I don't know about the starting crank but I 95% certain the ones in the engine wouldn't exchange. Good luck. SAm in NS
Brian
03-31-2002 12:30:28
 Re: Re: Will Cub crank fit into a super A ???? in reply to SAm in NS, 03-31-2002 11:12:00
Thanks for the response, it is the engine crank, as in crank shaft that I am asking about.
SAm in NS
03-31-2002 13:43:18
 Re: Re: Re: Will Cub crank fit into a super A ???? in reply to Brian, 03-31-2002 12:30:28
As Big John stated they are totally different engines. I'm certain they wouldn't interchange.
