Will a C crank shaft fit an A
Brian
03-31-2002 20:52:05
Sorry all... it's not a cub it's a "C" crank I would like to know fits into a "A Model"
Tim Malin
04-01-2002 19:12:10
 Re: Will a C crank shaft fit an A in reply to Brian, 03-31-2002 20:52:05
Please don't critcize me for being wrong, but didn't the C have the 123CID engine? If I am wrong, could somebody set me straight?
Bob
04-01-2002 20:04:45
 Re: Re: Will a C crank shaft fit an A in reply to Tim Malin, 04-01-2002 19:12:10
C had 113 and SC had a 123
Tim Malin
04-02-2002 07:57:46
 Re: Re: Re: Will a C crank shaft fit an A in reply to Bob, 04-01-2002 20:04:45
Gotcha. I own a Super M, and I am very fond of the Super Series. That is where I became confused. Thank you.
KURT
04-01-2002 08:09:32
To be really sure I would call a case IH dealer and get a professional opinion. I am not doubting any bodys skills here but I would want to be sure or you could get a I and T shop manual that might tell you.
Hugh MacKay
04-01-2002 06:24:16
Brian: The advice you have may have one little wrinkle. These tractors are now 50 years old and someone may have sliped a C-123 engine in there somewhere. Same basic engine, crank may be same. I am not sure but some one will check me up and thats what this is all about; you finding out before you spend money.
SAm in NS
04-01-2002 05:05:41
As the A,B,C,SA, all used the C-113 engine the crankshafts should interchange. Good luck. SAm in NS
Big John
04-01-2002 02:10:48
Brian: Now you are on the right track. The Farmall A, B, & C all used the C113 Engine and all parts will enterchange. GOOD WRENCHING.
