Order Farmall Cub Parts Online
Cub 184 Clutch removal
Bama Binder
04-01-2002 12:49:09
Can anyone give me the details on how to remove the clutch on a 184 Cub? I have the side panels off and the driveshaft/PTO cover off.
Do I need to remove the driveshaft first? I assume so but all I need to do is get the clutch unstuck. I was just going to loosen some of the bolts on the clutch in order to take some pressure off the pressure plate without totally removing them. Will this help? If not, which bolts on the clutch do I need to loosen?
Any help is appreciated. BB
Dale
04-01-2002 21:53:27
 Re: Cub 184 Clutch removal in reply to Bama Binder, 04-01-2002 12:49:09
before you take anythimg apart try this.Check to see that your release bearing fork is depressing your pressure plate right,then with clutch pedel in push or drive a gasket scraper between the clutch and pressure plate.Sometimes you can drive it with pedal in up some hills and they will come loose on there own.Also if clutch is loose a bad pilot bearing will act the same way.
