Shop time/cost to overhaul MTA's TA?
Al
04-02-2002 18:36:24
This is mainly for the professional tractor mechanics on the board: How much shop time does it take to split a MTA, and install a new TA? Not talking about a rebuild but split, remove the old one, pop in a reman, and do any other needed work while you're in there--seals, gaskets, maybe main engine clutch.
thanks,
Al
John In Iowa
04-03-2002 07:38:50
 Re: Shop time/cost to overhaul MTA's TA? in reply to Al, 04-02-2002 18:36:24
Get your checkbook out. While you are there you may as well do both clutches and have the flywheels ground. New bearings in both clutches and doesn’t forget the pilot bearing. Its takes a lot of work to get there so you may as well fix everything while you are there. May save you a big headache down the road.
John In Iowa
twopop
04-02-2002 19:57:18
shop time is now about $45 per hour
the tractor vet
04-02-2002 19:18:13
About 12 to 15 hours , some times thing go good then there are times that ya want to take a stick of dyamite to it and t/a will cost ya around 475 , gskt and seal kit around 67 rear main seal add another hour and not sure but around 25 to 35 bucks and if the t/a clutch is bad add for that .
