Over bore vs high altitude
Bob
04-03-2002 13:46:39
I am pondering whether to use overbore pistons (3 1/8 " instead of 3") or high altitude ones in my B rebuild. Any thoughts on which will net more horsepower would be appreciated.
gene b
04-03-2002 17:36:42
 Re: over bore vs high altitude in reply to Bob, 04-03-2002 13:46:39
go with the 1/8 over and hi-dome you will have 123ci.in. and 23 h.p. when you are done makes quite a difference if you want to machine the sleeves you can go to 3 1/4 bore
Steven@nd
04-03-2002 15:15:53
Most rebuild kits come with the option for step-head pistons, along with the overbore. For my 42 H, the step head was $10 more than flat top pistons. I couldn't find any sources for rebuild kits using standard bore pistons, unless going NOS.
Do both, these tractors were designed for 70 octane fuel, we now have 87 octane minimum.
Steven
john d
04-03-2002 14:01:47
Probably not a lot of difference. If your tractor was a "distillate" model that started on gasoline and then switched to distillate, you have a low-compression head. If that's the case, the high altitude pistons will simply put you at about normal compression for a gas engine.
You won't gain gobs of horsepower with either one by itself, but together you could get a very noticeable increase! There's no substitute for cubic inches when the tractor starts to lug under a heavy load. I'd say that if you're only going to do one of them, do the overbore kit. If I was into that many $$ on it, I'd do both.
Salvage Man
04-03-2002 22:00:55
 Re: Re: over bore vs high altitude in reply to john d, 04-03-2002 14:01:47
On the B farmall the pistons were different between the gas and fuel tractors. There used the same head.
john d
04-04-2002 05:52:54
 Re: Re: Re: over bore vs high altitude in reply to Salvage Man, 04-03-2002 22:00:55
Thanks for the info! I didn't know that. Just another example of how valuable these boards are for sharing details!
