Super C, How Big a Bush Hog?
Ben
04-04-2002 13:11:17
I'm looking to buy a pull type hog for my SC. What size should I look for? I don't want to overload and have to mow in 1st and full throttle. That's what a man said I would be doing with a 6'. I don't have a clue. Thanks for your help.
Paul JG.
04-04-2002 19:39:07
 Re: Super C, How Big a Bush Hog? in reply to Ben, 04-04-2002 13:11:17
I would purchas a over running clutch first thing and then A four footer if you are going to use it for heavy clearin,(small shrubs and such) if it will be just grass you could pull a five footer, but you will be working it most of the time and in lower gears.
Haas
04-04-2002 16:27:56
5 ft is the most you want, and be sure to get an over running clutch for the PTO.
Jimbub
04-04-2002 15:46:27
I run a 5ft. finish mower with my Super c and If grass is high or heavy it,s 1st.gear.
Dave 2N
04-05-2002 10:42:41
 Re: Re: Super C, How Big a Bush Hog? in reply to Jimbub, 04-04-2002 15:46:27
Ditto to wha you and Haas said: I run a 5 footer on my hills and it's strictly for keeping the fields open. I do it every year. But when the grass is heavy, it's first gear work. ORC is mandatory.
dan
04-04-2002 15:32:50
I have a 6 foot land pride finnish mower on a fast hitch to three point adapter. It is the heavy mower too not their light duty one. it cuts real good in second gear and doesnt push too bad when I push the clutch. my dad keeps saying I'm gonna put myself up a tree without an overrunner. just make sure your engine is tuned well and front weights help some. my engine is mildly souped up with firecraters and some custom work on the head but its only 8 or 10 horse more than stock.
superCmore
04-04-2002 13:57:54
I pull a 5 foot fast-hitch with my SuperC and it's all it wants and more sometimes!! Five foot would be the MAX!! Cmore
FC
04-04-2002 13:54:58
I use a 5' with my C. I would not want anything any bigger. The Super C would do a little better with it due to the slightly larger engine.
Dave_D
04-04-2002 15:09:42
 Re: Re: Super C, How Big a Bush Hog? in reply to FC, 04-04-2002 13:54:58
I have a 5 footer on my B (Same engine) and works fine. I run 2nd gear most of the time.
- Daev
