Super A ... This in no Crank call.
Bria
04-05-2002 08:46:38
Still working to find the right crank for this Super A ( Serial # 277186, year 1949, Model FAA ). I found a number on the old crank, it is 6402DC. This leads me to the next question. How many different cranks are there out there for A's ? Should I be looking for a crank with this exact number ? Are there any others that will do ?
As always, Thanks in Advance.
gene b
04-05-2002 18:24:32
 Re: Super A ... This in no Crank call. in reply to Bria, 04-05-2002 08:46:38
do you want a crank with bearings ready to run why dont you grind yours
Brian
04-06-2002 08:49:07
 Re: Re: Super A ... This in no Crank call. in reply to gene b, 04-05-2002 18:24:32
Gene, My crank appears to be cracked on the main bearing journal at the pulley end of the cranksaft. Second, the crank had already been ground to .020" already. I have found what I beleieve is a crank that has never been ground, at what I thought was a fair price. I called around a couple of local dealers, they all asked me for the number on the crank, when I asked if there were different cranks they said yes. And this is why I posted the original question because i would hate to receive a crank that wasn't the right one...
Tnanks for the responses.
scotty
04-05-2002 09:30:53
Any crank from an A, Super A, B, or C will work as long as the motor is 113 cu in. That number you found is just a casting number.
scotty
