IHC #8 Plow center bracket and rim
Andrew
04-06-2002 12:18:02
I am looking for a crazy wheel rim with a flat metal bracket welded to the rim for an IHC 2-14 pull type trip plow. The rim should have a flat piece of steel welded at four corners with one large hole in the center with 3 holes, for the bolts to go through. Any help, suggestions, or leads would be greatly appreciate. All I need is the rim and flat bracket for my plow. Thanks for the help!
Andrew
04-07-2002 10:23:41
 Re: IHC #8 Plow center bracket and rim in reply to Andrew, 04-06-2002 12:18:02
I am just looking for the center bracket and rim for a rubber tail wheel. I have a steel wheel on the back of the plow I have now. The plow was originally on steel and the front two rims have been converted from steel to rubber. Thanks for your help!
Thanks,
Andrew
Leadfoot
04-06-2002 19:07:58
Hi Andrew, I just picked up 2 #8 plows today that I'll sell parts off of, both have steel tail wheels (1 is REALLY good shape the other is usable). Are you needing the rim for a rubber tire tail wheel, or is an all steel tail wheel OK? BTW the mounting hub will accept either all steel, or, a rubber tire tail wheel. I am located in West central Ohio. E-Mail me if you are interested.
John S-B
04-06-2002 21:32:53
 Re: Re: IHC #8 Plow center bracket and rim in reply to Leadfoot, 04-06-2002 19:07:58
Leadfoot where are you located? I'm in west Delaware co. I have a #8 that I need some parts for. E-mail me your # and we'll talk $. Thanks JSB.
