460 Hydraulics
Bill
04-06-2002 15:44:24
Howdy: I was plowing with my 1960 Farmall 460 Diesel yesterday, and when I parked the tractor, I could not lower the implement. I have the Tel-a-Depth feature, and moving the lever causes no action whatsoever. I do not have anything handy to hook up to the other valves (since the plow is still attached) to see if it is the Tel-a-Depth or the pump. Any suggestions?
Thanks in advance!
Bill
Red Man
04-07-2002 11:34:20
 Re: 460 Hydraulics in reply to Bill, 04-06-2002 15:44:24
HD is right, I have a 460 Diesel and the engine has to be running for the lift to lower.
HD
04-07-2002 08:50:34
If memory serves me right, there is a valve to prevent the drawbar cyl. from moving if the engine is not running. OR, as mentioned, check the linkage on the left side, in front of the TC handle and also behind it that goes to the drawbar cyl HD
Red Man
04-07-2002 07:55:48
Sounds like some linkage has come loose. Does the engine pull down when you move the lever? Is there any resistance when moving the lever?
