Found that engine knock on the 300u
Arn
04-11-2002 05:38:31
Posted question earlier about the source of a engine knock. The knock was not from hydraulic pump but from the stablizer bar under the engine. The bracket holding the bar broke and when load was put on the front of the tractor the bar would bounce against the oil pan, broke a hole in the oil pan and put a ding in a piston bolt on the crank shaft. I'm very lucky the crank shaft is fine it just cost me a new bracket and a oil pan. Next question, I was told this is a weak spot on the 300u's, did this bracket break because of age or is moving round bales 1000 to 1200 pounds to much for this tractor. I have a do-all loader and that and the hydraulics work great but can they lift more than the tracor can handle? Any input would be greatly appreciated.
Steven@nd
04-11-2002 08:22:46
 Re: Found that engine knock on the 300u in reply to Arn, 04-11-2002 05:38:31
I would say a 1000lb bale is too much for such a small tractor, that's why pieces started to break. The loader on our 1256 is a Farmhand F235 and that even cracks once in a while with our 1500lb bales! Not to mention we pretty much tore the whole front axle to pieces one time loading manure with it.
One thing about these tractors and loaders is that the loader will generally lift more than the tractor can handle at any more than a slow speed. It only takes 1 hole to break an axle.
Steven
No Gas Cap Yet
04-11-2002 19:47:48
 Re: Re: Found that engine knock on the 300u in reply to Steven@nd, 04-11-2002 08:22:46
I sent away for two gas caps with the form that steven@nd posted about 3 weeks ago and nothing. whats the deal?
Zonie
04-11-2002 21:30:25
 Re: Re: Re: Found that engine knock on the 300u in reply to No Gas Cap Yet, 04-11-2002 19:47:48
It took me about 3 months to get mine, They seem to send them out in batches. I had clean forgot I even sent for it when it came.
