560 turbo
BZ
08-06-1999 11:39:00
Just received a copy of the literature for the new turbocharger with dry-type air cleaner. The following is what it says. When properly installed, this turbocharger can provide your 560 diesel tractor with improved fuel economy and full rated horsepower at higher altitudes. all necessary installation parts-plus a new 176 cfm capacity dry type air cleaner are included. The part number should be 407 055R91 for $462.00. I think this is from a 1967 parts & accessory booklet.. Any one ever seen one. BZ
Bermuda Ken
08-07-1999 05:46:26
 Re: 560 turbo in reply to BZ, 08-06-1999 11:39:00
I have always believed that IH offered the turbo kit for the 560. I know the kit WAS NOT made just to be operated at higher altitudes, instead just to help give the engine a lil power boost. I'm not aware of this turbo kit being offered by IH when the 560's were in production. It was offered after the 1206 was announced, as IH was still "playing" with turbocharger technology back then. When the 1206's were being developed, the "weak link" on the tractor was the rear tires. The side walls would buckle and the tire would spin off the rim. Another case of too much IH power!!!!!
andy
08-06-1999 16:04:39
Yes I have seen the book I have seen tractors with then on .they did offer them .now try and get the people to belive you
Harold H
08-07-1999 05:37:01
 Re: Re: 560 turbo in reply to andy, 08-06-1999 16:04:39
OK, I believe you. However the literature says it was for high altitude which I suspected and mentioned previously and we were definitely not in a high altitude area in the Mississippi Delta. I guess that is why we never saw or sold one. Also by the date it was offered 560's were no longer a current tractor or considered a high horsepower tractor in our area.
Harold H
Seeing Red
08-07-1999 03:22:44
I KNOW IH made these turbo kits as we had a 560 and had one installed in the '60's. It made for a very nice pulling horse-the only drawback was it seemed to break head bolts and blow head gaskets often. Lots of power though. A neighbor of mine is still running his 560 turbo. He had his installed around the same time.
Wayne
08-07-1999 03:04:43
There was a lot of this done around here in the early 60's. The neighbor had one and said it would put out 92 hp. I haven't seen one for 20 years. He pulled a 5 bottom steerable plow with drag in 2nd gear.
Kev Believes in iowa
08-06-1999 17:18:12
All they have to do is visit there IH dealer, of course it helps if the shop forman is over 50 years old. Ps don't visit during planting or harvest, they have to much to do then to talk.
08-06-1999 17:18:04
