Help identify
Albert
04-12-2002 12:09:57
Hey, I am going to look at and maybe buy a basket case. The man told me the front end is missing, but it is just like a A, but the rear end has the same length axles on each side. I thought a B at first. Then he said that with the rear rims off it measures around 40 inches from hub to hub. Is that measurement anywere close to a BN?? Are they more or less BN,s then there are B,s??? Thanks Albert/FO
TNR
04-12-2002 14:44:49
 Re: Help identify in reply to Albert, 04-12-2002 12:09:57
40 isnt right for a BN.It may be one of the shopmules.I think they share some of the same sheetmetal with the A,or maybe not,Im not sure,havent seen but a couple.
wade tubbs jr
06-28-2002 00:45:57
 Re: Re: Help identify in reply to TNR, 04-12-2002 14:44:49
I also believe that i have a shop mule mine has a factory gas pedal one foot brake with individual hand brakes under seat also shifting likage runs from shifter to tranny under seat in rearend no drawbar or pto just penal hithch believe it was originally yellow i have a farmall bn also grill is the same except for one says farmall on it and one says international hopefully i will have a scanner pretty soon so i can post some pictures hope this info helps you . e mail me at wjost4@yahoo.com
Red Dave
04-12-2002 12:24:52
40" hub to hub is not enough for a BN. From your description, I don't know what it might be, but 40" is pretty narrow.
There are fewer BN's than B's
