LIFT ALL
Dip Stick for an M Farmall
BIG JOHN
04-12-2002 16:57:27
I have seen several posts wanting to know how to check the oil level when you no longer had a dip stick. Went out today and measured mine. HERE IS THE SCOOP on how to make your very own.
You will need a a piece of 1/8" rod 12" long and a fender washer that is 3/4" in diameter.
Attach the fender washer 1/2" from one end of the rod. Make a mark with a file 2" from the other end. (You are done)
The fender washer will keep the rod (now dip stick) from droping into the body of the lift all and will still allow the cap to screw on. The 1/2" of rod sticking above the washer gives you something to get a hold of. The mark at the 2" level is the FULL mark. There was no ADD mark on the orginal. GOOD WRENCHING
Norm
04-15-2002 11:55:00
 Re: LIFT ALL - Dip Stick for an M Farmall in reply to BIG JOHN, 04-12-2002 16:57:27
Will this same length work for an H?
Norm Sketers
04-15-2002 11:52:34
This looks great for an M but will it work for an H? is there a length difference?
Chris
04-12-2002 19:52:32
I did something similar.I did'nt have the original oil fill cap so i used a 3/4" pipe cap drilled a 1/8" vent hole in the side and drilled a 1/4" hole in the top then welded in a 12"
piece of 1/4" smooth rod but until I read this I did'nt know where to put the full mark . thanks
Tom W
04-12-2002 17:32:53
Thanks Big John, I went though the articles today and found a post that said the full mark was 9 1/4 down from the top of the fill pipe. Thats pretty close to you measurements. Thanks again for you help. Tom
