A,B, C
BrianV
04-16-2002 07:00:17
The Farmall A,B & C all came with the 113 cid engine, what made the HP different. Displacement or Transmission????
Thanks in advance!!
BIG JOHN
04-16-2002 14:37:11
 Re: A,B, C in reply to BrianV, 04-16-2002 07:00:17
The A,B,C & Super A all used the C113 engine and they all were the same horsepower. There were some early A's and B's that did not have starters or a place to install one. The C and Super A had hydraulic pumps that the A & B did not have. There were some late C's and Super A's that may have had water pumps.
Gene
04-16-2002 07:31:27
Brian: You can NOT change horsepower of a machine with a transmission. Only the sorce of power, the engine, can be changed. The tranny just changes speed of the output. Slower speed will have more torque. Fast speed less torque. G.
gene b
04-16-2002 07:11:31
A,B and C were the same engine SUPERC was 1/8 larger sleeve and ran more rpm any A,B or C can take the same sleeve and pistons to make them 123cu in and speed the engine up also
