Farmall M wiring problem
Bob Bennett
08-06-1999 23:27:52
Recently bought a Farmall M that had a unfinshed backyard 12V conversion done with alternator. I'm in need of a wiring diagram showing how to connect all the components. Including all the contacts in the light switch/ammeter box with fuse, push/pull-ignition switch with two leads, alternator with Bat/r/f wiring connections, ballast resistor, 12V coil, distributor. I got the lights to work so I know they are hooked up correctly. The light switch only has three positions on it chg/dim/bright. Thanks for the help. Fax # (360) 697-7747
