Wide Front B
BrianV
04-16-2002 14:20:50
Can you get a wide front for a Farmall B?
BrianV
04-17-2002 06:30:37
 Re: Wide Front B in reply to BrianV, 04-16-2002 14:20:50
I like the front just like it is,however my wife has been talking to our #@%#@ neighbor and has her thinking it will roll over. I didn't have 3 boys so I could cut the grass... The B has a 5' Belton mower which is great because we live in Texas. Thanks I know where I can get a B front, I will keep the narrow front for after the kids move out.
Roger
04-16-2002 19:10:51
Brian, A guy I work with said that the ginsing farmers in Wisconsin convert their Farmall A's to look like a B with a wide front end. They take the left axle casting off of a B and put it on an A. That makes the A look like a B with a wide front. They also take the B drawbar and use it. This makes the tractor more stable on hills. Roger
Dave_D
04-17-2002 08:42:27
 Re: Re: Wide Front B in reply to Roger, 04-16-2002 19:10:51
I guess that would work if they took the both rear axles and the draw bar off the B and put them on the A. I believe your idea would work if you took the left axle off of a BN and the drawbar off a BN.
gene b
04-16-2002 19:34:56
that wont work as the drivers side axle on a B is not the same as an A the drawbar wont fit the drivers side axle housing on an A is 4in shorter therefore the drawbar will be to wide you can change the front and put an A on a B you can put the front from a b and put on an A also stop telling tall tales about what you heard I have done both ways depending on what someone wants for a mower or something else but you will run into drawbars fitting when you start changing around with axle housings and so forth
Dave
04-17-2002 06:45:24
 Re: Re: Re: Wide Front B in reply to gene b, 04-16-2002 19:34:56
The drawbar info is correct, the B's that I have seen in Wisconsin have a wide front that has
been built by someone. They are not fronts from
a Farmall A.
Dave G
04-16-2002 16:18:53
Sure - you could put an A front on the B. Like said earlier the grill and steering shaft might have to come from the A too.
Red Dave
04-16-2002 15:53:35
You could put the front end from an A on a B. You would need to use the steering bolster & grill too. I think you would have to do some modification to the steering shaft too.
It would eliminate the ability to mount B implements like cultivators though.
Richard C
04-16-2002 14:59:09
I have seen a wide front on a B at a show once. Man it looked good I don't know for sure what it came off of to begin with but it can definately be done and done good. I could send you a picture if you want. I dont know if I can get it onto my computer would probly have to mail it. So no they didn't come that way but can be done.
Richard C
Steven@nd
04-16-2002 14:32:11
Never came that way from the factory, but I have seen a wide front from an A put on a B - it wasn't pretty.
I'm not sure the way the bolster is set up on a B, but I think it is different from a C so that front end probably wouldn't fit either.
The short answer to your question is "no".
Steven
Hugh MacKay
04-16-2002 15:34:17
 Re: Re: Wide Front B in reply to Steven@nd, 04-16-2002 14:32:11
Not sure this would look very good either Steven, put front bolster of C on B. Since steering shaft on C is on right hand side, you could put the operator on oposite side. On second thought would look like H@#$ to, and cost a lot of money.
gene b
04-17-2002 08:51:03
 Re: Re: Re: Wide Front B in reply to Hugh MacKay, 04-16-2002 15:34:17
HUGH you are right you can do anything there is some talk of states putting the A front on a B for hi-way mowing had one of these got in COLO was originaly yellow dont know if a town or where it came from just stories there was a B on a sale here that they put the seat in the middle moved the clutch on the left side added another u-joint in the steering and moved the wheel a little to the middle didnt sell very good had a baler motor for engine also then an alt very expensive to redo
