Wanted rear rim and center bracket for IHC #8 Rubber Plow
Andrew
04-17-2002 15:54:28
I am looking for a rear rim for a rubber IHC #8 plow. The rear rim has one large center hole with 3 holes for the lug nuts to go through. I am just looking for the rim and center bracket ONLY. The center bracket is welded at four corners on the the 12 inch rim. Any help, suggestions, or leads would be greatly appreciate. Thanks for your help!
TomM
04-18-2002 18:35:50
 Re: Wanted rear rim and center bracket for IHC #8 Rubber Plow in reply to Andrew, 04-17-2002 15:54:28
My IHC rim was rusted out. I bought a new blank rim from Miller Tire Co. Then welded the old center bracket in the new rim. Miller Tire also have round implement tires.
Jon,NH
04-18-2002 04:06:00
Is this rim ....by your discription it is solid rim with lug nut holes,are these holes equally space?I have a trailer mower that runs a similar wheel,i wonder if its basicly the same?Do you have a picture so i can compare?
Andrew
04-20-2002 09:54:38
 Re: Re: Wanted rear rim and center bracket for IHC #8 Rubber Plow in reply to Jon,NH, 04-18-2002 04:06:00
I am really seeking a wheel off an International plow. I don't think a wheel off a mower will fit, but I am unsure. I don't have any pictures at this time to compare the wheel with a crazy wheel from a mower. Thanks again for the help!
