140 drain plug sites.
Al Schuman
04-18-2002 19:43:17
Doing major P/M, Location of the transmision plug, small plug on lower front left of trany? Rear axle drain large plug lower back right side? Rear axle housing shows it takes 2 3/4 pts each, where to drain and fill? manual not much help here. Thanks for anyones help, want to do it right. Al
Haas
04-20-2002 07:57:40
 Re: 140 drain plug sites. in reply to Al Schuman, 04-18-2002 19:43:17
The Final drives do not have drain plugs. You have to drop the pans that cover the bull gears. Get new gaskets first and fill back up to the bottom of the fill plug hole that is on the inside of the final drive casting just above where the pans bolt on.
Bigdog
04-19-2002 03:52:23
Not sure about the 140, but on the cub, you have to drop the pans off the bottom of the final drive housing to drain them. The fill plug are inboard, recessed plug with a 1/2" (approx)square opening. You can loosen them with a 1/2" drive ratchet. On the cub, you have to move the drawbar to get to one of them.
