C113 Engine Experts
HELP!!!!!!!!!!!!!!11
BIG JOHN
04-19-2002 15:53:24
Purchased a "B" about a month ago. This tractor seems to have had a good life living with it's former owner who took good care of it. Looks like new.
Here is the problem and I know you guys have probably been here before. There is a rattle in the front of the engine (not a knocking a rattle)When I changed the oil I droped the pan to clean out any crud (not hardly any)and everything looked good. I have disconnected the generator and the rattle is still there. Next will be the fan, but sounding scope says that probably isn't it eather. At this point I am thinking the govenor might be the problem.
If anybody has had this problem or has an opinion, please give me an idea on this.
gene b
04-19-2002 17:14:20
 Re: C113 Engine Experts - HELP!!!!!!!!!!!!!!11 in reply to BIG JOHN, 04-19-2002 15:53:24
sounds like the cam gear might have been replaced and the teeth are a little too tight meshing with the gear on the crank and the gear on the governer drive had this happen once only way to tell for sure is remove the steering pedestal rad ect and pull the front cover and check the lash between the teeth
cd
04-19-2002 16:13:54
maybe your cam gear or one of those is loose.
