Loader for Farmall A.
Brian
04-20-2002 19:55:04
I about to pull my hair out.
I have a PTO driven hydraulic pump,valve and resovoir for what I think is a Henderson loader. Somehow I think Char-Lynne comes into play here as well.
My problem is that it just doesn't seem to generate the pressure needed to raise the lifter. It will pump with no load, I can manually lift the bucket (defeats the purpose ) and it will stay. It also goes down fine.
When I look through the fill plug I can tell there is oil going all over inside there, it's very turbulant.
Does anyone have any experience with these ?
Looking for some suggestions.
thanks. Brian.
tiny
04-21-2002 05:41:31
 Re: Loader for Farmall A. in reply to Brian, 04-20-2002 19:55:04
you need to post a picture of your farmall A with a loader. pleasssss sseeeee
gene b
04-21-2002 03:25:25
are you runing it the right direction are you running with chain or belt what speed are you running they are not to run over 6oorpm there are gaskets inside fron the pump to the outlets that could be blown you can get a parts and manual fromEATON CORP FLUID POWER OPERATION MINN.DIV 15151 HWY5 EDEN PRAIRE MN 55344 TELE 612-937-9800 these are very good units i use three of them two on Bs and the other one an A
Brian
05-09-2002 22:46:31
 Re: Re: Loader for Farmall A. in reply to gene b, 04-21-2002 03:25:25
Thanks for the reply. I will give them a call.
