966 hydralic problem-Help
Andy in Ga.
04-21-2002 09:21:11
When it is cold and i crank my 966 none of the hydralics work. It won't move or steer. It has to run for 30 min. sometimes before I can steer it. If I park the front end down hill overnite it runs fine. What's causing this?
c.b.
04-22-2002 09:31:47
 Re: 966 hydralic problem-Help in reply to Andy in Ga., 04-21-2002 09:21:11
We had the similar thing happen on one of our 1066 about 10/11 years ago. Till it warned up (10/15 sometimes 30 minutes) the T.A. was stuck in low, the steering was hard to turn and the brakes were weak. Once it warmed up everything worked fine. This would even happen after the hydraulic filter was change. When we removed the mcv plate to look at the steering pump. We found the keyway was sheared off on the pump. And after warming up it would finaly snag and drive the pump. We also say that the steering pump showed alot of wear so it was replaced along with repacking mcv block. Its been working fine since then.
good luck
Andy in GA
04-22-2002 12:12:26
 Re: Re: 966 hydralic problem-Help in reply to c.b., 04-22-2002 09:31:47
Thanks, I'll give that a try and see what happens. That sounds like a good possibility. This tractor has run a couple hours a day for over 25 yrs. I use it to dig silage out of a pit. ANDY
cb
04-22-2002 19:18:02
 Re: Re: Re: 966 hydralic problem-Help in reply to Andy in GA, 04-22-2002 12:12:26
That 1066 we have is getting old but still going. She got a fresh engine and turbo a few years back and is expected to earn her keep for some time yet. When they brought her home new in the fall of 1973 my older brother's would not even let me drive her for about a year. It was our first diesel tractor and thy didn't trust a 14 yrs old on it yet. But I had already learned to disk and cultivate with the old 806 gas. Use to get me mad when they let my first cousin ,1 1/2 yrs older drive it. I thought I could run it as good as him. But since then have spent many hour driving a 1066 my favorite tractor. By the way we have three of them. Two 1972's and one 1973.
Andy in Ga
04-22-2002 19:57:32
 Re: Re: Re: Re: 966 hydralic problem-Help in reply to cb, 04-22-2002 19:18:02
Bought the 966 new in 1972. I also have a couple 1066 and a 5488. The 966 is my favorite. My dad bought a couple of 560's in 1962. We ran them for years until we bought the 966 and I thought it was the biggest tractor I ever saw. The 560's are gone, wish I had them back.
RPM
04-22-2002 06:31:41
If its cold and hydraulics are erratic its probably water in Hytran, take out filter and see if water/ice in housing, examine color of Hytran to see if discolored, genuine will hold some water in suspension, it will be creamy if overloaded. The first thing to try is new Hytran & filter. This system holds about 22 gallon with filter change.
Andy in Ga
04-22-2002 07:02:25
 Re: Re: 966 hydralic problem-Help in reply to RPM, 04-22-2002 06:31:41
Have checked all that and it was fine. I went ahead and changed it anyway . still does it
RPM
04-22-2002 14:13:07
 Re: Re: Re: 966 hydralic problem-Help in reply to Andy in Ga, 04-22-2002 07:02:25
You didnt say if the rear couplers & hitch are not working or if the steering/TA-brakes system has stopped, if both have stopped the pumps draw Hytran from a common reservoir, however there are still 2 separate systems. Front pump in MCV on side of clutch housing runs steering/TA-brakes, rear pump below left brake runs rear frame hydraulics, hitch & couplers. If both have stopped would recheck oring & gasket on hydraulic filter cover, can have vacuum leak.
Andy in Ga
04-22-2002 14:19:34
 Re: Re: Re: Re: 966 hydralic problem-Help in reply to RPM, 04-22-2002 14:13:07
Rear couplers and hitch both work. Power steering and transmission don't until the tractor has run about 30 minutes and then works fine the rest of the day.
