Rough running 560
AJ560D
08-08-1999 03:46:19
This spring our 560D would rev up on its own for a few seconds the return to set speed. Now it's doing it all the time.If you let it go it will return and run fine.But if you throttle back,it will run rough for about a minute then straighten out.This problem is getting worse as the summer goes on.Also it doesn't smoke at all while it takes it's fit. Thanks for any help.
sjk
11-10-1999 15:15:06
 Re: Rough running 560 in reply to AJ560D, 08-08-1999 03:46:19
Do you know how many hours are on the injection pump? It is possible the pumping plungers are scored or the advance piston is sticking. But you said that there is no white or black smoke comming from the engine and usually these problems are accustom to smoke. Or it could be a governor problem.
Redfan
08-08-1999 05:12:39
AJ,
You may have already tried this, but the first thing I would do is check all the filtering. It sounds from your description very much like a fuel starvation problem. Good luck, Redfan.
sid
08-08-1999 06:18:08
 Re: Re: Rough running 560 in reply to Redfan, 08-08-1999 05:12:39
make sure the fuel return line is open.
