I-H 140 snow blade
Al Schuman
04-26-2002 19:05:22
Does anyone know of one for sale or what the price range would be?? Thanks ahead of time for help. Al in o-HI-o
Haas
04-27-2002 05:25:24
 Re: I-H 140 snow blade in reply to Al Schuman, 04-26-2002 19:05:22
I've seen two of these for sale recently. One was at an auction with a Super A (all for sale together with several other implements) They did not get the minimum bid, so I think the owner still has it. Also there is one (a bit rough)at the show here in East Tenn going on righ now. Roy Edwards has it. Don't know what he is asking. Phone number is 423 892 5289. He is in East Ridge, TN, near Chattanooga. Might could find the phone number for the one with the Super A, but that would take a bit more research.
Al Schuman
04-28-2002 04:58:49
 Re: Re: I-H 140 snow blade in reply to Haas, 04-27-2002 05:25:24
Thanks but Tenn. would be a bit far for that, I`m in o-HI-o Neighbor saw one go for $175.00 at a recent sale, wish I would have known!! Al
Hugh MacKay
04-26-2002 19:54:02
Back ten years ago I was much like yourself. I don't believe a lot of these snow blades were sold new with these tractors. I fabricated a blade. My blade is a 6 foot angle blade. The push arms go back under front axel and hook to a pivot point just below clutch housing. The part they hook to is bolted in same two holes as side dresser uses plus the hole on bottom of clutch housing. That frame is also braced on each side to the final drives. Those braces are quite important, I broke a clutch housing learning. These little tractors are quite agressive in their ability to push. My blade is made from a sheet of 1/8" steel I had rolled. There are 4 curved uprights welded to back of blade 3/16" x 3" and a 1" x 1" angle on top and a 3/8" x 2" x 2" angle on bottom that cutting edge bolts to. The lift mechanism hooks in right rockshaft and goes over axel to a chain that lifts blade. If you have more questions ask. I like this blade better than the factory blade.
Al Schuman
04-28-2002 10:07:49
 Re: Re: I-H 140 snow blade in reply to Hugh MacKay, 04-26-2002 19:54:02
Hugh, do you have drawings or sketches this sounds doable. Thanks Al
