Hydralics plumbing
Bill Ramsey
05-02-2002 07:03:48
Could someone post a diagram of how the hyd. should be plumbed on 53 super H Mine looks like a very poor plumber did the job. I have a I&T manuel but don't show much. I just bought Fay's book sure a good book.Thanks much Bill
Bob M - email problem?
05-03-2002 04:55:53
 Re: hydralics plumbing in reply to Bill Ramsey, 05-02-2002 07:03:48
Bill - I emailed 3 photos to you last nite. I received the error message (below) this morning. Post back whether you received my email - if not I'll resend...
----- The following addresses had transient non-fatal errors -----
----- Transcript of session follows -----
... Deferred: Name server: moment.net.: host name lookup failure
Warning: message still undelivered after 4 hours
Will keep trying until message is 1 day old
Hugh MacKay
05-03-2002 02:55:21
Some of those Hs and Ms and Supers had some weird and wonderful hydraulic plumbing. I would bet there were variations in the 100ths, and all of them worked. I remember my dads first H with a loader. He said the day it was delivered, "We will not dare go near tree limbs on headlands when loader is off". Seemed like the guys hooking these up were trying to keep pipe and fitting industry healthy.
Bob M
05-02-2002 08:08:00
Bill - Post back whether your SH has belly pump or live hydraulics. I have a pair of '53 Super H's - one is set up each way. I will take/post digital photos of either (or both...) hydraulic setups if you wish. ...Bob M
Bill Ramsey
05-02-2002 11:02:19
 Re: Re: hydralics plumbing in reply to Bob M, 05-02-2002 08:08:00
It must be a belly pump and has plumbing coming out of the top of that part in front of bell housing which I guess is the resivoir. Is that right? thanks a bunch. Bill
Bob M
05-02-2002 13:00:11
 Re: Re: Re: hydralics plumbing in reply to Bill Ramsey, 05-02-2002 11:02:19
Bill - That would be a Stage 1 non-live hydraulic setup, also known as countershaft-drive Liftall or "belly pump". I'll email several photos of mine from home this evening. ...Bob M
Steven@nd
05-02-2002 07:35:30
Do you have the live hydralics? I assume so. Our Super MTA looks like a plumber's nightmare also, but that is the way it came from the factory. Just a couple of hoses running along the frame and block that go to the control valve and reservoir. Link has a pic that shows the hoses on our SMTA.
Steven
