Crankshaft and flywheel
Bruce
05-02-2002 10:32:35
I'm restoring an F30 and am pulling everything out the the block to hot tank it. All is out except for crankshaft. Have puller on flywheel, but it won't budge. Is it possible to pull crank and flywheel as one assembly? Flywheel has holes which look like they line up with rear main bearing cage bolts. Also, if crank and flywheel can be removed as one unit, can a new rear oil seal be installed? I have the seal, a round piece of felt. Any advice would be highly appreciated.
David Saville
05-03-2002 22:28:07
 Re: Crankshaft and flywheel in reply to Bruce, 05-02-2002 10:32:35
Did you find the locater pin between the crank and the flywheel? It is threaded so you can put a bolt in it and pull it out. I think when I did my W30 I pulled the crank and flywheel as one piece but they have to come apart to change the bearing. I think I also put the flywheel back on before I put the crank back in the block. Sorry about the "I think" but it is a few years since I did mine.
