C CARBURATOR
BOBBY
05-03-2002 05:44:58
I WAS NEEDING TO KNOW IF THE CARB. OFF OF A C FARMALL WORK ON A S/C. ANY INFO WOULD BE APPRECIATED. THANKS BOBBY
gene b
05-03-2002 20:11:07
 Re: C CARBURATOR in reply to BOBBY , 05-03-2002 05:44:58
why not the super only has 10 more cu in hobody changes carbs when they put a fire crater sleeve and piston set in tons of them were done here as everyone had to have more power for their Ms and carbs were not changed go ahead it will run just fine i never change carbs when i put the larger sleeve and pistons to make a B 123ci in and they all run just fine have even used the CARTER from a SC on a reg B with no problems go for it gene b
BIG JOHN
05-03-2002 13:23:20
NO - NO - NO Only the Carter carb UT733S or SA will interchange. The Zenith for the "C" is 161X7 10386 and the model for the "SC" is 67X7. Marvel Schebler did not make a carb for the "SC". I am sure that all of them will bolt up but they were jeted differently for the "SC"
I am needing a carb for my "C" so have been researching this just today.
Dudley
05-04-2002 06:35:49
 Re: Re: C CARBURATOR in reply to BIG JOHN, 05-03-2002 13:23:20
Saw a Carter UT on E-Bay the other day. Don't know if it's still there. Started at $20.00, probably not that now, who know's!!
FC
05-03-2002 06:24:31
Should work. Most C's and Super C's had either the Carter UT or Zenith. My C has the Carter UT as do a lot of Super C's. If you happen to need a diagram/specs of the Carter I have one scanned I can email to you.
BOBBY
05-04-2002 12:04:51
 Re: Re: C CARBURATOR in reply to FC, 05-03-2002 06:24:31
YES I WOULD LIKE THE DIAGRAM IF YOU WOULD BE SO KIND TO SEND IT....THANK YOU BOBBY
