Farmall h popping
bob
05-09-2002 17:57:52
I just recently rebuilt motor and carb. on my H and when it is running it has a slight popping sound from the exhaust. I thought carb. needed adjusted but when I turn the needles they don't make a difference. Also when you let out clutch motor boggs a little bit then picks back up also does this if using brakes to turn. This happens at any RPM. I was thinking maybe sucking air around manifold? Could this cause this? Thanks!
Bama Binder
05-10-2002 08:58:45
 Re: farmall h popping in reply to bob, 05-09-2002 17:57:52
I think after a rebuild and some run time, it would be good to go back in and check the valve lash...that can cause popping because the valves can open prematurely if there isn't enough clearance.
my.02
joe
05-09-2002 20:12:37
bogging down when turning hard is just natural, i think
Craig MO
05-09-2002 19:21:12
You could have a leak around manifolds. I would probably pull valve cover and recheck my valve settings first. You might also want to recheck timing.
Dan Kelley - Quick way to check manifold leaks
05-10-2002 07:03:46
 Re: Re: farmall h popping in reply to Craig MO, 05-09-2002 19:21:12
A real quick way to check manifolds for leaks is to get some carb cleaner. Squirt a little cleaner around the flange of the manifold. If you detect a slight change in the way the engine is running, you've found a leak. On tractors, it will be a more subtle change than on cars, so you need to listen pretty carefully.
Michael Soldan
05-10-2002 16:12:18
 Re: Re: Re: farmall h popping in reply to Dan Kelley - Quick way to check manifold leaks, 05-10-2002 07:03:46
Dan, some propane( from an unlit torch ) directed around the manifold will cause the engine to smooth right out if there is a leak because the propane is sucked in and burns as a fuel, you can use acetylene for good results as well.You can definitely tell by the sound of the engine. Mike in exeter ontario
Dan Kelley
05-12-2002 11:14:33
 Re: Re: Re: Re: farmall h popping in reply to Michael Soldan, 05-10-2002 16:12:18
I'll remember that. That's a good tip for when I don't have carb cleaner handy.
