Splined shaft fix?
Bama Binder
05-10-2002 13:44:13
I have a steering shaft that is hollow and is splined. I had to remove the steering wheel and the years and rust took its toll.
Bottom lin is when I got the puller on it, I crushed what was left of the shaft. I got the wheel off OK, but now I have to fix the shaft. I have located a replacment steering box and shaft but they want big$$$.
The shaft is splined as is the steering wheel. I can get a new steering wheel but doubt I can find a shaft with the same splines to weld on.
Question: Would it be reasonable to have a machine shop weld on a threaded bolt to the shaft to bring it back to the correct length and machine in a woodruff keyway into the shaft and steering wheel. I would also have to have a plate welded on to keep the wheel from slipping down the shaft.
What do you think...go that way or spring for the replacement steering box $250???
Andy Martin
05-10-2002 15:31:05
 Re: Splined shaft fix? in reply to Bama Binder, 05-10-2002 13:44:13
A good machine shop can also cut splines into a solid shaft which you could then weld to your old shaft.
lc
05-10-2002 15:11:37
Don't know to recommend yes or no but instead of welding on a flange put a taper with a keyway.
