Knocking in Farmall H second gear
Bryce
05-16-2002 16:21:15
I bought a 1941 Farmall "H" about seven months ago. When I bought the tractor it had a knock in second gear, But heck! I got a hundred dollars off the price. We have the deck off and the tractor split in half. We have the top main shaft drive and main drive gear. It makes a knocking noise in second gear like a crank with the pin that falls up and down to keep it from un cranking. It seems to do it the most when it is free wheeling or rolling down hill. Thanks! and you can also e-mail me at Jeffg245@hotmail.com
TNR
05-16-2002 19:25:27
 Re: Knocking in Farmall H second gear in reply to Bryce, 05-16-2002 16:21:15
Why would you be freewheeling it?Might have a tooth off a gear or a bad bearing.
Casey
05-16-2002 17:41:24
Your NUTZ for spliting the tractor to do a tranny job on an H! i bought an H about 7 months ago too and i boguht it as is, and it had a terrible nock ni all gears! which indicated the consant mesh and main drive gears were chiped. to make a long story short just drop the hydrolic pump and and clutch and unbolt your shafts and pull them out!
i just finishe mine fri afternon still havnt goten arond to start it and test it out!
-casey :any advice just holla
