Lo-boy 154 start gen. swap to alt. ?
Belt Buster
05-20-2002 20:21:26
Evenin I have a pickle here and wondered if my 1970 Cub Lo-boy 154's generator starter can be replaced by somethin that really works cause mine don't. Or rebuild-replace the old gen. start? Also wanted info on steering wheel and dash plate for this ol' tractor which is really in fine shape overall. Thanks Belt Buster
mel
05-21-2002 04:03:27
 Re: Lo-boy 154 start gen. swap to alt. ? in reply to Belt Buster, 05-20-2002 20:21:26
Take the starter-generator to a generator shop and have them rebuild it. I just did that to mine and it cost $35. They put in one brush and cleaned the commutator and replaced a bearing. Tractor runs great. I have used my 154 for the past 25 years cutting grass with a IH 3260 72" mower and have had no problems whatever. Change the oil often and don't forget to check / add hy-tran fluid to the transmission and final drives. I use prestone and distilled water in the cooling system and watch the level. Keep the antifreeze 2" below the level of the cap because it is a thermosyphon system. Other than that good preventive maintenance is the key. good luck !
