Farmall Super A
BigAWB
05-21-2002 09:27:06
Where do you look to find what year a Super A is? I'm sure it has to do with the serial number, but where do you locate that?
Red Dave
05-21-2002 09:36:34
 Re: Farmall Super A in reply to BigAWB, 05-21-2002 09:27:06
A Super A should have the tractor serial number on a plate, about 4" X about 5" mounted on the inside of the seat mounting bracket.
It should start with the letters FAA and have 6 numbers after that.
If you can't find it, post back.
scotty
05-21-2002 09:32:59
ID plate on seat support bracket there is also an
ID number stamped into the engine block under the number #1 plug. There are also casting codes on various cast parts of the tractor.
scotty
BigAWB
05-21-2002 09:44:25
 Re: Re: Farmall Super A in reply to scotty, 05-21-2002 09:32:59
Thanks a lot, I now have a starting point. Just inherited 2 Super A's
scotty
05-21-2002 11:24:23
 Re: Re: Re: Farmall Super A in reply to BigAWB, 05-21-2002 09:44:25
Congrats they are great little tractors!
scotty
