Knocking in '41 Farmall H second gear
Bryce Andreasen
05-21-2002 19:03:39
I have a knocking noise in second. I have the deck off and the tractor split. I have the top shaft to the trans. but still cant see anything wrong. Thanks!
jal-SD
05-22-2002 06:29:01
 Re: Knocking in '41 Farmall H second gear in reply to Bryce Andreasen, 05-21-2002 19:03:39
Did you check the ball bearings on the axes & the brakes? Sometimes you can hear when a bearing is out or going out as it will give you a knocking sound in 2nd & 3rd on H's & M's. (My $0.02 worth. jal-SD)
