Think I got me a stock 2nd puller
Bob-Wyo
05-29-2002 20:29:43
Pulled the 350U @ 5300#,May 5th, got results today, the little guy did great in 55oo# open, 3rd place behind 2 88 OLLie's, right on the heels of one,(5 feet)
beat out JD-G,JD-50 & 49 IH MD.
This was done in 2nd gear, started out in 2nd high and dropped to 2nd low, love that TA,
blew it in the 6500#, didn't pull the TA soon enough. but still another 3rd, well what else only 3 in the class. (ER88 and a very good JD G.
It is absolutly stock, motor never been opened, pulling off the 2 point @ 20" hitch.Never lost steering.
Got to get this baby down under 4500, but hate to give up the 4 wheel weights.
Now anybody got some hints how to better this little puller? A picture of it is in the photo section.
Thanks for letting me blow/brag here.
Bob
joe
05-29-2002 20:40:46
 Re: Think I got me a stock 2nd puller in reply to Bob-Wyo, 05-29-2002 20:29:43
i'm not sure how to remove lots of weight, but do they let you take sheet metal off? you would loose 50# there. And then you can take the PTO off, since you most decidedly will not be needing it.
And take off any hydraulic valves you have, and if you have a hydraulic drawbar (2 pt. hitch) take it off and put a conventional one on. Take headlights off, you will loose a few pounds there. Just strip everything that is not absolutely necessary. Heck, take the knob off the gear shift for all that matters!
