Farmall Super A Touch Control Hydraulic leak
Brad Harper
05-31-2002 05:57:52
Hi. I have a hydraulic leak coming off the Hydraulic reservoir on the right hand side. The leaks are at the rear connection to the reservoir and the forward connection just below the coil. I retightened the bolts but she still drips. Are there gaskets that I can replace or is there a better way. Any help would be greatly appreciated.
geoff gauger
05-31-2002 10:24:56
 Re: Farmall Super A Touch Control Hydraulic leak in reply to Brad Harper, 05-31-2002 05:57:52
There is a gasket where the steel tubes bolt to the reservoir and two O-rings at the pump connection.
Brad Harper
05-31-2002 14:47:31
 Re: Re: Farmall Super A Touch Control Hydraulic leak in reply to geoff gauger, 05-31-2002 10:24:56
Geoff:
Do you know where I would be able to purchase the gaskets and o rings?
Brad Harper
BIG JOHN
05-31-2002 16:53:45
 Re: Re: Re: Farmall Super A Touch Control Hydraulic leak in reply to Brad Harper, 05-31-2002 14:47:31
Just purchased these from the local CIH dealer last week. They were in stock.
Brad Harper
05-31-2002 19:02:20
 Re: Re: Re: Re: Farmall Super A Touch Control Hydraulic leak in reply to BIG JOHN, 05-31-2002 16:53:45
Thanks Big John. I will contact the IH dealer here in Dickson TN.
Brad Harper
03-13-2003 13:10:46
 Re: Re: Re: Re: Re: Farmall Super A Touch Control Hydraulic leak in reply to Brad Harper, 05-31-2002 19:02:20
Yes the O rings fixed the problem no more leak on the right. Side!
