IH B250 Problem
Bear
06-01-2002 08:38:06
I seem to have a problem with diesel fuel leaking into my oil pan on my B250. Could this be a cracked head gasget or some other problem? I have to change the oil every couple months because the level keeps rising.
Klein Rot
06-03-2002 10:56:24
 Re: IH B250 Problem in reply to Bear, 06-01-2002 08:38:06
Sheck the sealing of the fuelfeedpump, when this one is leaking the fuel can get right into the oilpan
Hugh MacKay
06-01-2002 12:25:52
I would consider looking at the possibility of fuel leaking past seal on injection pump shaft. I can't remember what pump your B250 has. I had this happen to two tractors over years and both had Rosa Master pumps. One IH and one Deere. Be careful it thins out your oil quite quickly.
Bear
06-25-2002 18:46:32
 Re: Re: IH B250 Problem in reply to Hugh MacKay, 06-01-2002 12:25:52
Did you replace the seal or fuel pump?
Was this an easy thing to do, and if so, what
steps should I take.
Thank you
Manuel
06-01-2002 22:02:02
I think they had Minimec or Cav pumps.
