Specs. For Farmall A
Andrew (OH)
06-02-2002 13:53:37
I may be getting an Farmall A and I need to know exactly how wide and long these things are. I also need to know how much they wiegh. Also what is the going sale price for a fully restored A. I'm in central Ohio.
Thanks, Andrew
CNKS
06-02-2002 18:27:07
 Re: Specs. For Farmall A in reply to Andrew (OH), 06-02-2002 13:53:37
Gene b gave you the price range -- I'm not in the market for one, as I have a Super A (not restored) that I gave $1850 for including a belly mower. I would not pay more than $2500 for one in perfect condition, particularly a straight A (no hydraulics). It would be difficult to get an A to weigh more than a 1/2 ton pickup and a tandem axle trailer could handle.
BIG JOHN
06-02-2002 14:31:07
Andrew, you might want to allow a little more width as tires mounted in or out and wheel weights could add as much as 20". Gene B.'s measurement is the axel width end to end. If you are asking for hauling reasons I sure would also ad several hundred pounds like Gene says for fluids and weights etc. GOOD LUCK
gene b
06-02-2002 14:16:26
54x108 aprox wt around 1600 depending on wheel weights fluid in tires ect restored depends on quality of job correctiveness decals 2500-4000 prices you ususlly gat what you pay for too many unknown things new engine correct tires for original the right size when you say restored you are opening up a large area who says restored how well do you know an A FARMALL
